Anyone need slush busters
briggie1
I was at an auction and they had a case of slush busters. I bought the case. They will be $12. If anyone needs any pm me
Slo-Ride
They work great.. Last year I had a problem with the wiper arm stripping out the grooves and was left with freightliner not being able to replace arm with the exact one. In order to replace arm I had to buy another style arm and remove the keyway. Not say these slush buster caused this but I have no other reason to believe it didn't either.. I religiously and manually move the wipers when frozen in place as muchbas possible.. Wish I had enough faith in them to use them again but with no replacement parts from freightliner..I am gunshy. They do work good.
tknight
Did you get proper replacements? I think our trucks are alike??
Yes bought new arms and they came with washer jets got them at Youngs fl in Columbus one rainy day they work great now the springs were shot and had little pressure on the windows don't forget they are different from left to right also. Brilliant engineering job!
Slo-Ride
Yep went the routine with freightliner.. There tech shop even said only repair is to change entire wiper transmission due to a change in vendors.. Or remove keyway .
Skyline
Mine split open two years ago and I had to put a hose clamp around it next to the road in the rain. I am slightly embarrassed to say that it is still there, but it works perfectly!
Slo-Ride
That there is a preety good tactical repair :cool:
I went with a 2 part epoxy that didnt hold to long but did get me home.
RETIDEPXE
My M2's driver's side stripped out due to ice freeze up. FL told me as well need complete assembly. Tried JB Weld, nope. Then I drilled a small hole thru the arm and into the wiper shaft, tapped it out and put a screw in. Worried it wouldn't hold i bought a used assembly for $30 on ebay. That was some years ago, the screw is still working and the used part hangs on the wall in my garage.
I've never had a need for them in all my years....DeIcer works great and window defroster as well....that and a good set of winter blades....
