Tennesseahawk
I've heard several ppl (and three orientations) say to accept every load, because you never know what you'd miss on the other side. I could say the opposite is also true... you don't know what load would come up next unless you turn the first one down. Or worse yet, you'll find out and be pizzed. Case in point... Run from Houston to Wichita on a Monday. Nothing the rest of the week, and last straw for my co-driver. We found three very good runs out of Houston the next two days. This Monday, Detroit to Plainsville, IN. Turned it down. Took one from Livonia to Louisville and was pre-dispatched picking up in Louisville to Denver.
Now, Denver could be a curse or blessing depending on what comes out of here. But my point is, the safe bet isn't always the first thing to pop up. I could've gotten a load out of IN to TX, but I chose to roll the dice. Ends up I pulled dispatch out of the fire two loads in a row, and probably picked up points because I turned one down. I don't believe in favors with dispatch (at least not with my former companies), but I do believe part of the job is taking care of your dispatch when they need you to. It amounts to recognition. They will remember your loyalty and dedication (especially with smaller companies). And I don't concider that a favor... it's business.
