ac
starbryte
about a year ago trucker mag had a picture of a new type of electric ac which installed without hooking to the cooling system. some models even performed heating task as well as ac. anyone know where i can price this unit?. I think the ubit just nmounts under the seat and runs on battery power only. Ill die without ac this summer any suggestions/ do i need to sell this truck and get one with ac?
Bigschu2
Here is a little more information click below on the link
www.tundra.cc/tundra/.
There is a model listed here that has shore power or an inverter that gives hours of operation without running truck engine. Then you can use trickle solar power(probably not included) to charge the batteries later. It's a good Idea to use seperate batteries other than the mains for this though. Optional shore power will charge the batteries back or the trickle solar will do the same. Problem is how often do you or will you be able to plug into shore power. Better off going the solar trickle route.
Hope this helps!
Mark
comfort king
Sounds like the unit you are reffering to is the Bergstrom NITE System. It does fit under the bunk and provides heat and cool. We isolate a couple of batteries from your starting batteries and let your charging system recharge your A/C batteries as you drive down the road. Call us, we can help. 800.837.3900
