After sitting for a day 1/2 finally got a mechanic. After explaining symptoms and applied remedies the unit was moved to a spot where the rear was slightly downhill. The new filter was removed, contents poured into a pan. No contaminants. Primary pump activated, mostly air. Fuel being low, @ 15 gals each tank, it was thought maybe I had too little fuel. Added 30 gals. Still not coming up. Blew through lines back to tanks, both bubbled. Blew towards filter into top of tank, mostly air. Should be a diaphragm in pump that blocks direction. I think pump is bad but doesn't explain after pump times out. Possibly still low fuel problem, depends on pick-up tube location in tank. Should be on bottom where 15 gals. shouldn't be a problem. I still think there is something I am missing. Previous owner thought a sensor failed as happened to him in the past. Shop says no 02 sensor. Anyway shop closed at 5:00 Friday till Monday morning. Motel till then, Welcome to ownership!
