Thought I would pass this along.
Ring Power Cat Dealer in Jacksonville Fl.
904-737-7730
Talked to Don Hutchison about rebuilding or replacing a cat3126
He states that per cat they no longer need to be replaced short of a cracked block.
Cat now has a sleeve installment that they use on a rebuild. They do have to machine the cylinder walls if they are pitted. Which he says is very rare. Most rebuilds are around $3,000 with warranty and $6,000 with a out of frame rebuild. Add some money if you replace turbo to have it covered under warranty as well. Most dealers tell you to replace engine in order to sell you a new one. He states that is not the case. He says only a few have ever come in that they couldn't rebuild. (because block was cracked).
I was always under the impression that they could not be rebuilt, or it was extremely expensive. He says that is a myth and is not true.
So if you need a rebuild ect., call the above.
Hopefully it helps someone out of a jam
904-737-7730
