2004 M2 fuse box????
gutovicobren
Anyonw knows where is fuse box with fuse for cigarette ligher. I found the one under the hood but its not there, so there must be one more???
Sent from my SAMSUNG-SGH-I337 using EO Forums mobile app
tknight
Mines in the main box it's one of the spare fuses I just love how poorly stuff is marked! NOT!!!!!!
gutovicobren
Its not possible that there is no other fuse box. Light fuses are not there cig. lughter fuse is not there and many more. So therr must be another fuse box somewhere.
Doggie Daddy
I believe that IS the only fuse box, but you need the owners manual to see what each fuse is.
Sent from my SCH-I545 using EO Forums mobile app
Doggie Daddy
The first thing I would do is test every one of the fuses in the main box under the hood to see if they are all working.
runrunner
Google is your friend. (maybe)
I found this in another forum so check it out.
s at the rear of the vehicle -
on a cross member between the two frame rails. Totally exposed to
road slop and moisture. Back where you get down on your back and
scoot forward on your butt with dust and dirt sifting down in your
face - there on the rearmost cross member is a black box with lots of
cables including one large red clad cable that brings power back from
the battery. I actually found it by sound. I had the four ways on and
since that circuit was working I could hear the relay clicking and
that homed me in on the location after I was in the right
neighborhood from reading the manual.
tknight
The bulkhead module controls the lights so I don't think it uses fuses must have auto resetting breakers in that mystery box
RETIDEPXE
You may have an inline fuse in the dash for the cig lighter, but i would test all the fuses under the hood before going there. The fuse block under the truck on the cross member has all the fuses for the tail, brake, park, fog and running lights if I remember correctly, also contains relays for these and yes, flashers that go click click click.
