06 ud clutch problems
towmater
I am working on a 06 us 2300lp with a jo8 hino engine. Last week thought the clurltch disk froze to the flywheel. We could push the clutch in and would not shift. After playing with it for an hr or so we pushed the clutch in and gave the shifter pull the truck lunged and then everything worked as it should. Then yesterday it did it again in the middle of the day.
This truck can not be started in gear that is why didn't just shut it off shift it in to gear and start it back up.
We are in snow country and have 2ft of snow now and has not got above freezing in a month.
Anyone have any thoughts.
The slave cylinder is moving the release arm correctly? Does this one have a slave cylinder return spring?
towmater
Yes they have a spring in the out side that pulls on the arm to keep tension so the rod from the slave does not pop out.
